#69104 - 09/02/2002 11:01 [searches] in config.ini?
loren
does anyone know what the:
[searches]
amount=0
flag in config.ini is for?
|| loren ||
#69105 - 09/02/2002 11:58 Re: [searches] in config.ini? [Re: loren]
adavidw
Loc: Utah, USA
The [searches] section is where the number of saved searches you've defined in emplode go. For example, mine looks like this:
[searches]
amount=1
and then there are separate sections for the actual search, like on mine:
[search0]
expression=play_count>10
type=advanced
name=playcount
-Aaron
#69106 - 10/02/2002 01:21 Re: [searches] in config.ini? [Re: adavidw]
Wow, that's nice. I didn't realize emplode would be storing those on the player. I thought they would go into the local system registry. But if you think about it, it makes more sense to store them per-player.
Anyone want to make sure that gets into the documentation at riocar.org?
#69107 - 10/02/2002 11:28 Re: [searches] in config.ini? [Re: tfabris]
loren
fancy! i didn't realize that either. Thanks for the explanation.
|| loren ||
#69108 - 10/02/2002 11:57 Re: [searches] in config.ini? [Re: tfabris]
loren
Oh man... i started to add that info to the dev section, then i realized just how many new fields need to be added. Maybe i'll get to that tonight when i have some more time.
|| loren ||
